Poroelastic model_undefined variable kd
Posted 2022/10/26 2:51 GMT-4 Structural & Acoustics, Acoustics & Vibrations Version 6.0 2 Replies
I am using three Physics for the acoustic simulation, including Pressure Acoustics (acpr), Solid mechanics (solid), and poroelastic waves (pelw).
The poroelastic waves model I used is Biot-Allard (thermal and viscous losses). Also, the Biot-Willis coefficient is set to "Rigid assumption".
After setting all the parameters in the materials and in the Physics, which means no warning sign (STOP) in all of my setting. I still receive the following error message after starting the study:
- Feature: Stationary Solver 1 (sol1/s1) Undefined variable.
- Variable: Kd
- Geometry: geom1
- Domain: 1 Failed to evaluate Jacobian of expression.
- Expression: dvol*((1/comp1.pelw.rho_c)*(comp1.pelw.delta*(-(comp1.pelw.p_t*(comp1.pelw.ik^2))))) Failed to evaluate Jacobian of expression.
- Expression: ((-comp1.pelw.gradpX*comp1.pelw.gradtestpX-comp1.pelw.gradpY*comp1.pelw.gradtestpY-comp1.pelw.gradpZ*comp1.pelw.gradtestpZ-comp1.pelw.p_t*test(comp1.p2)*comp1.pelw.ik^2)*comp1.pelw.delta/comp1.pelw.rho_c)*(dvol)
Apparently, I need to define the "kd (drained bulk modulus" as it is used in the Biot-Wills coefficient (as in the brochure of COMSOL's Acoustic module.), but there's no such parameters in the variables nor in the materials (I checked this part with Ctrl+F and looked into every setting in comp1.).
Furthermore even it is not necessary to define the Biot-Willis coefficient, I still set a number(1 or 0.8 or 0.3, just making trial and error), however the error message (above) didn't change.
I assume that this Kd is the key to solve the Jacobian of expression error also...?
Could someone give me a hint what could be the error message came from? Also, is the kd error message a bug or my wrong setting?
