State-Space reduction
Hello, I have a quick question, Is it possible to perform State-Space reduction in COMSOL and export the matrix? Thank You
4 Replies Last Post 2022/11/09 14:52 GMT-5
Remi Magnard COMSOL Employee
Posted: 3 years ago 2022/11/08 2:44 GMT-5
Updated: 3 years ago 2022/11/08 3:40 GMT-5
you have two options to export your COMSOL model to a state-space system: add a State Space node in the solver configuration or create a modal reduced-order model (ROM).
Which one to use depends on the problem you want to solve. I would recommend you to use a ROM as you have full control on the reduction; however, it requires that the physics interface supports an eigenvalue/eigenfrequency study. The first option (using a State Space node) can be used for any physics interface but does not provide any reduction; the size of the exported system is the same as the full model.
To extract the matrices either use a Matrix Evaluation node in the Model Builder or use LiveLink for MATLAB to extract them at the MATLAB prompt. To read more about state-space systems, I can recommend you to look at the COMSOL Multiphysics Reference Manual and the LiveLink for MATLAB User's Guide.
I hope this will help!
Hi, you have two options to export your COMSOL model to a state-space system: add a State Space node in the solver configuration or create a modal reduced-order model (ROM). Which one to use depends on the problem you want to solve. I would recommend you to use a ROM as you have full control on the reduction; however, it requires that the physics interface supports an eigenvalue/eigenfrequency study. The first option (using a State Space node) can be used for any physics interface but does not provide any reduction; the size of the exported system is the same as the full model. To extract the matrices either use a Matrix Evaluation node in the Model Builder or use LiveLink for MATLAB to extract them at the MATLAB prompt. To read more about state-space systems, I can recommend you to look at the COMSOL Multiphysics Reference Manual and the LiveLink for MATLAB User's Guide. I hope this will help!
Posted: 3 years ago 2022/11/08 14:10 GMT-5
Thank You Remi, I am using heat transfer in solid pysics, just to confirm, if i use ROM, will I be able to export the matrices from the reduced model?
Posted: 3 years ago 2022/11/09 3:03 GMT-5
Yes, with the Heat Transfer module you can compute eigenvalue for heat transfer in solid, and so generate a modal reduced model to extract state-space matrices.
Posted: 3 years ago 2022/11/09 14:52 GMT-5
Thank you Remi.
Thank you Remi.
