Stationary study fails, but time-dependent study completes
When running a stationary study, I receive an error:
Feature: Stationary Solver Failed to find a solution. Singular matrix.
However, when running a time-dependent study, I do not receive any errors and the study finishes.
What could be causing the stationary study to fail in this situation? My model involves a solid block with wells and fractures inside. It couples Solid Mechanics and Darcy's Law with the Poroelasticity interface.
Thank you.
2 Replies Last Post 2022/11/10 13:55 GMT-5
Posted: 2 years ago 2022/11/10 2:18 GMT-5
Chances are large that you have too few constraints, so that there are possible rigid body modes. Then a dynamic analysis will run, since the inertial forces will ensure a force balance.
Henrik Sönnerlind
COMSOL
Posted: 2 years ago 2022/11/10 13:55 GMT-5
Thank you, Henrik Sonnerlind! I solved the issue. My matrix permeability was set to 0 m^2 and I solved it by making it a very small value instead, 1e-100.
Thank you for your response!
Thank you, Henrik Sonnerlind! I solved the issue. My matrix permeability was set to 0 m^2 and I solved it by making it a very small value instead, 1e-100. Thank you for your response!
