Nils Malm
COMSOL Employee
2012/09/25 17:57 JST
In the PDE interfaces, the curl (and also div-) elements are only available when the number of dependent variables is the same as the space dimension. The reason is that, conceptually, each PDE interface works with one physical quantity (you cannot set different units for different dependent variables). Normally, this imposes no limitations, but there are cases where you may need to model also the out-of-plane component of a vector. I guess your case is something like that.
There are two possible work-arounds: either you can split your equations into more than one PDE interfaces, such that you can select curl elements for two of the components; or you can add a weak contribution (from More on the interface context menu) and then an auxiliary variable as a subfeature to the weak contribution. The latter may be the best option if your problem is indeed about an out-of-plane component of a vector.
best regards
Nils Malm
COMSOL AB
best regards
Nils Malm
COMSOL AB
