Microwave not heating, but cooling. Why?
Posted 2012/09/17 15:01 GMT-4 RF & Microwave Engineering, Heat Transfer & Phase Change Version 4.2a, Version 4.3 7 Replies
When I do the transient study with exactly the same model, the initial temperature is a proper 293.15[K]. The fixed temperature region I set remains a proper 293.15[K], and as time progresses, the temperatures elsewhere rise as expected. The transient study works. The stationary seems to be all low by 19 degrees.
I've looked everywhere for an errant temperature setting. Is this a Comsol bug?
I'm not so sure you will find a "bug" that easily ;),
I assume rather a sign error or just a mesh density issue ,
what is your time stepping, and material thermal diffusivity alpha and how does it compare to your mesh density ?
be aware that when you change a lot a model, including changing nodes in the solver, at some stage COMSOl cannot find its way and does not always continue to update the solver nodes, as it considers that the user has change so much that it's the user responsability to update the nodes.
Theerfore it's worth to always restart fresh, and if the solver is giving doubtful results, to delete the full solver sequence and restart a fres new "default " solver sequence, the only thing is that then mostly you loose all your postprocessing set-up too
I can see getting errors. For example, if I change physics, I often get the "Unexpected error" dialog, which is easily resolved by clearing things out and reloading. It's a bug, but a benign bug.
On the other hand, it's decidedly non-benign when COMSOL gives totally incorrect answers with no error or warning, as happened to me when switching between the stationary and transient solvers in microwave heating. It's exactly that sort of non-benign problem that erodes trust in the software. After all, software like COMSOL is not useful to an engineer if the results are untrustworthy. I'm not talking about limitations of the finite element method itself. I'm talking about software bugs that radically alter numerical results. Scary.
Have you contacted technical support (support@comsol.com) with your question and model? We would very much like to investigate the problems you are having with this model. We do have plenty of customers simulating microwave heating successfully and we are not aware of any general issues.
Bjorn
I'm also a "user" and live from delivering "correct" simulations, but I must say that for all of the numerous software I have used so far, the things you can do with COMSOL is far above average, if not unique. But, on the other hand, the complexity and number of buttons, tweaks etc also increases exponentially, therefore I only trust models build up rather directly.
Once I have tested out and run different combinations, if I have any doubts, I remake my model fresh to be sure I have all corret "default setings" and no mixed combinations from different tries.
But this was so also for other tools, for me this is no "bugs" when the software delivers probably "correct" result from some "incorrect" settings, the thing is to track and identify the "wrong" setting.
So with some perhaps strict methodology, and systematic validation of my models, I'm very happy, and get rapidly great results, I never had dreamed of possible, before ;)
Have fun Comsoling
I am working with light, so use refractive index for the materials. When the imaginary part of the refractive index was negative, I also got cooling. So it might be a sign problem.
The microwave heating node is behaving strangely in 4.3, with repeated crashes. I can't get Port to work, while it works fine with EM-node. I suspect Comsol mixes the variables between the two nodes, E and E2, as I have used both in the same model. Deleting EM-node and Reset history does not help. See attached example if you are interested. I will send it to support also.
Comsol is ok. The error-messages are not.
Olav
Suggested Content
- BLOG Heat Transfer in Biological Tissue with Thermal Damage Analysis
KNOWLEDGE BASE
How can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling? - BLOG COMSOL Conference 2015 Boston Award Winners
- FORUM Heating & cooling In COMSOL
