temperature effect on SAW eigenfrequency analysis
Hi all,
Now I want to analyse the temperature effect on SAW eigenfrequency analysis. There is a similar tutorial in comsol model library named saw_gas_sensor.mph. That simulation is done in room temperature, now I want to calculate the eigenfrequency in 40 degree. So I add 'thermal stress' and add 'temperature' boundary. But it gets a wrong result. Could anybody help me? Thanks.
zhanggazi
3 Replies Last Post 2012/09/28 15:58 JST
Posted: 1 decade ago 2012/09/27 5:39 JST
I have the same problem, when I modify the temperature there is no change in the frequency response. I would like to ask for help with this issue.
Hi, I have the same problem, when I modify the temperature there is no change in the frequency response. I would like to ask for help with this issue.
Posted: 1 decade ago 2012/09/27 15:01 JST
but how do you add T effects?
a) in PZD you can only add thermal expansion (for the volume hence inertia change) for linear materials, not for the PZD term, and
b) then you need to also adapt the physical material properties to get these correctly changing with T
Hi but how do you add T effects? a) in PZD you can only add thermal expansion (for the volume hence inertia change) for linear materials, not for the PZD term, and b) then you need to also adapt the physical material properties to get these correctly changing with T -- Good luck Ivar
Posted: 1 decade ago 2012/09/28 15:58 JST
Hi Ivar,
I added linear thermal expansion for linear materials, in my case aluminum, but this is not enough for my research. The problem is that I want to modify the temperature of the PZD term (substrate LiNbO3) and thus observe a change in the frequency response of the admittance. The substrate has a variable T, which I can change, but there is no change in the admittance. How I can integrate this variable T in the behavior of my model? Can you help me? Thanks
Hi Ivar, I added linear thermal expansion for linear materials, in my case aluminum, but this is not enough for my research. The problem is that I want to modify the temperature of the PZD term (substrate LiNbO3) and thus observe a change in the frequency response of the admittance. The substrate has a variable T, which I can change, but there is no change in the admittance. How I can integrate this variable T in the behavior of my model? Can you help me? Thanks
