Unable to call external data file
Does anyone know how to import an external data file as a heat source. I am trtying to do it but when I call it, I get this error message of "unknown function or variable". Not sure what's going on.
To import an external data file,
I am going to function>interpolation>import data file, the fucntion has a name to call, lets say int1, but I am unable to call it.
In the heat transfer module, in place of Q0, I try to call it by int1, and with arguments int1(x,y,z), still get the error. Any suggetsions are welcome.
6 Replies Last Post 2022/12/23 12:33 GMT-5
Jeff Hiller COMSOL Employee
Posted: 3 years ago 2022/12/21 10:57 GMT-5
Updated: 3 years ago 2022/12/22 8:36 GMT-5
One possibility is that you are trying to call the function outside of its geometric scope, see this old thread. If that's not the issue, can you upload the model file?
Jeff Hiller
One possibility is that you are trying to call the function outside of its geometric scope, see [this old thread](https://www.comsol.com/forum/thread/312723/unknown-variables?last=2022-09-01T17:32:02Z). If that's not the issue, can you upload the model file? Jeff
Posted: 3 years ago 2022/12/21 19:09 GMT-5
Hi Jeff,
Thank you very much for the response. I dont quite understand how to call the fucntion outside its geomtric scope when I am not able to assign a geometry to it. Proabably I am missing something here. I have attached my model file, please have a look at it and let me know where I am doing wrong exactly.
Regards, Kunjalata
Hi Jeff, Thank you very much for the response. I dont quite understand how to call the fucntion outside its geomtric scope when I am not able to assign a geometry to it. Proabably I am missing something here. I have attached my model file, please have a look at it and let me know where I am doing wrong exactly. Regards, Kunjalata
Posted: 3 years ago 2022/12/21 19:30 GMT-5
I encourage you to upload the external data file as well.
Posted: 3 years ago 2022/12/22 8:46 GMT-5
Updated: 2 years ago 2024/04/08 14:37 GMT-4
Hello Kunjala,
1/ I would place the definition of int1 in Component1, not in Global Definitions since it appears you want to use it for a spatially-dependent function in Component1.
2/ Your definition of int1 states it takes 2 arguments, but then you call it with 3?!? There's clearly an issue there.
Jeff Hiller
Hello Kunjala, 1/ I would place the definition of int1 in Component1, not in Global Definitions since it appears you want to use it for a spatially-dependent function in Component1. 2/ Your definition of int1 states it takes 2 arguments, but then you call it with 3?!? There's clearly an issue there. Jeff
Posted: 3 years ago 2022/12/23 12:32 GMT-5
Hi Jeff,
Thanks a lot.
It works now.
Kunjalata
Hi Jeff, Thanks a lot. It works now. Kunjalata
Posted: 3 years ago 2022/12/23 12:33 GMT-5
Hi Robert,
Thanks a lot for the response. It works now.
kunjalata
>I encourage you to upload the external data file as well. Hi Robert, Thanks a lot for the response. It works now. kunjalata
