Bending test on Shape Memory Alloy
Posted 2023/03/14 0:04 JST Structural Mechanics, Material Models Version 6.0, Version 6.1 4 Replies
I am trying to simulate, through a stationary solid mechanics model, a bending test on a pseudoelastic NiTi tape. I fitted the Lagoudas material model through experimental tensile tests and I am able to properly capture the mechanical response at different test temperatures.
When I model the bending test on the tape, the model is able to capture the experimental loading phase but the simulation fails during the unloading (it stops before the backward transformation from martensite to austenite). In particular, the following error is displayed:
"Failed to find a solution for all parameters, even when using the minimum parameter step. Failed to compute elastoplastic strain variables. Returned solution is not converged. Not all parameter steps returned."
Thank you for helping me!
