Vacuum properties
Posted 2012/10/10 8:17 GMT-4 RF & Microwave Engineering Version 4.3 10 Replies
While doing eigenfrequency analysis on rf module of a cylinder, if the geometry consists of only a cylinder, the cylinder is assumed to be standing is vacuum. Can I change the surrounding medium to be say "water" or "glass" without increasing the computation volume size?
In order to include the space around and its properties you MUST define a respective domain. You can use PML (perfectly matched layer) to reduce the required size of the domain around your device.
Cheers Edgar
But, doesn't this imply that one has to do a parametric sweep to find the modes of the cylinder i.e. taking an excitation port or working with a background field and solving for the scattered field? Am I correct on this?
I would answer : it all depends,
you can either do an eigenfrequency analysis, that solves for the energy modes, and rather easily,
or do a frequency domain sweep, hence solving a harmonic development of the equations (with a source of given amplitude and phase) and observe the modal response, which takes usually longer to solve
I have another doubt regarding the eigenfrequency analysis method. Some of the solutions that are returned have complex frequencies. Why does this happen?
Cheers
Edgar
have have seen sometimes complex values (if very small imaginary parts for cases when I would have expected only real, so these are probably "eps" tricks leftover. Anyhow more than 5-6 digits with todays double floating is illusory, so very small values, compared to much larger related ones, also betwen real andimaginary, I always consider as numerical noise.
Binary representation of real number is a sampling theory with more holoes than continuum ;)
Thanks a lot for all the responses ....
yeah .. this was something I used to see earlier when I worked for a short while on COMSOL. Then, the imaginary part was quite small. so, I was not concerned. This time around I was working on lossy media, so, just wanted to confirm the reason for the large imaginary parts.
Thanks Ivar for the quick responses...
I have the same problem this discussion started with, and unfortunately I am quite new to the use of comsol.
For brevity, I want to solve an eigenfrequency analysis of a box filled with air, surrounded by water. How can I implement this kind of analysis?
I mean, how can I make the software understand that inside the box there is air( for which I do not need to calculate the eigenfrequencies) and water outside?
Can anyone help me?
Eigenmodes with damping have complex Eigenfrequencies. So in the real world all modes should be complex. I don't know if COMSOL has a threshold for displaying the imaginary component. Or maybe the purely real Eigenfrequencies are assumed without damping, not sure here.
Cheers
Edgar
I was assuming that, whenever there is no damping, the eigenfrequency calculation of Comsol should always return real values, since there is no damping, there are no shift of the locations of the nodes/peaks with respect to time. It may be an attention point if the imaginary part is greater than the real part though, or if you have no damping in your system but you are still getting imaginary values with small imaginary parts, which may indicate a poor (lossy) mesh.
/Onur
Suggested Content
- BLOG Predicting How Long Coffee Stays Warm in a Vacuum Flask
- KNOWLEDGE BASE "Data access entity removed" occurs in my application
- KNOWLEDGE BASE New Free Space workflow for some AC/DC interfaces
- KNOWLEDGE BASE Error: Singular Matrix
