Multicomponent multiphase flow
I am currently simulating a model in which the two carrier phases involved are water and toluene and the diffusing components are acetone and methyl isopropyl ketone (MIPK). This problem is to be solved using the Stefan-Maxwell equations together with the Navier-Stokes equations.
I have the inlet composition and the velocity conditions. I am in a fix as to which model is to be used for this. I have used the pde mode general form for Stefan-Maxwell equations and single phase Incompressible flow model for Navier-Stokes (each phase). I am attaching the model herewith. I am getting some results, but when I change the channel dimensions, the profiles of concentration and velocity do not change.
5 Replies Last Post 2014/06/13 21:46 JST
Hello Siddharth Kulkarni
Posted: 1 decade ago 2013/02/24 23:25 JST
Have you got a solution for this problem?
Best Regards,
Natan
Hi, Have you got a solution for this problem? Best Regards, Natan
Posted: 1 decade ago 2013/02/24 23:35 JST
I sorted it out somehow. I think the trick is to stick to the general mode pde form for more flexibility. Yet, I am not 100 % sure whether I have applied all the boundary conditions correctly. However, COMSOL exhibited convergence and results were reasonable enough.
Hi, I sorted it out somehow. I think the trick is to stick to the general mode pde form for more flexibility. Yet, I am not 100 % sure whether I have applied all the boundary conditions correctly. However, COMSOL exhibited convergence and results were reasonable enough.
Posted: 1 decade ago 2014/06/12 18:50 JST
just a question, which model did u use to solve the problem?
Posted: 1 decade ago 2014/06/12 18:59 JST
I used the PDE general mode (mathematics).
Hi, I used the PDE general mode (mathematics).
Posted: 1 decade ago 2014/06/13 21:46 JST
Hi, do you know how to use multiphysics to solve the multiphase flow?
