Is there any way to debug in COMSOL? I mean, to solve step by step
Hello, I think this is interesting.
It would be very useful for me if there would be a way to run a model step by step. I am working in Time Dependent, with PDE equations, and I cannot find the mistake that exists in my model...
When this things happen in MATLAB, the best you can do is to run your program step by step, checking and evaluating the variables, until you find why it does not work...
Any trick to do this in COMSOL?
Thanks a lot!
7 Replies Last Post 2012/10/15 20:12 JST
Posted: 1 decade ago 2012/10/14 1:22 JST
often you get clues of what is wrong by first running for the initial conditions (possible as specific commands in 4.3a (&3.5a), from 4.0 to 4.3 you need to run the solver sub-node: dependent variables
Hi often you get clues of what is wrong by first running for the initial conditions (possible as specific commands in 4.3a (&3.5a), from 4.0 to 4.3 you need to run the solver sub-node: dependent variables -- Good luck Ivar
Posted: 1 decade ago 2012/10/15 18:01 JST
thanks a lot, was helpful to know that ;-)
Another "problem" I have just realized about...
I have some variables that depends on a lot of things, and all of these are dependent on the time. I am using PDE and time dependent solver, so I see the evolution of my variables along time. That works fine.
I have a very interesting plot that I use to "debug", I mean, to say if everything seems to go right. This plot would be perfect if I could show it for a concrete instant 't'.
Do you have any idea about how I could do that?
(explaining myself a bit better: I run the study from 0 to 1 sec, in steps of 0.001). I would like to see the value of all my variables for t=0.57s, for instance).
The plot is well done, because if I disable the PDE, I see that it works fine for the initial parameters and variables values
Thanks a lot!!
thanks a lot, was helpful to know that ;-) Another "problem" I have just realized about... I have some variables that depends on a lot of things, and all of these are dependent on the time. I am using PDE and time dependent solver, so I see the evolution of my variables along time. That works fine. I have a very interesting plot that I use to "debug", I mean, to say if everything seems to go right. This plot would be perfect if I could show it for a concrete instant 't'. Do you have any idea about how I could do that? (explaining myself a bit better: I run the study from 0 to 1 sec, in steps of 0.001). I would like to see the value of all my variables for t=0.57s, for instance). The plot is well done, because if I disable the PDE, I see that it works fine for the initial parameters and variables values Thanks a lot!!
Posted: 1 decade ago 2012/10/15 18:14 JST
once you have run a simulation you can see the results at any of the intermediated stored solutions (time or spatial all depends onyour model), or you can define a Data-Set extrapolating to the spatial or time desired value, when you have not stored the exact value, but twopositions around the point of interest
Hi once you have run a simulation you can see the results at any of the intermediated stored solutions (time or spatial all depends onyour model), or you can define a Data-Set extrapolating to the spatial or time desired value, when you have not stored the exact value, but twopositions around the point of interest -- Good luck Ivar
Posted: 1 decade ago 2012/10/15 18:22 JST
Ey, thanks a lot for the incredibly quick reply!
Yeah, I am sure there should be a way to do it, since the data is calculated and stored.
I might by skipping something, but my question was how to plot those results at a certain time? Because I know how to plot a variable vs. time, vs. and expression, etc. But I do not know how to make a plot like:
y vs. x at t=0.57s
Sorry if I misunderstand something in your reply, but I still do not know how to do it.
Thanks a lot in advance!
Ey, thanks a lot for the incredibly quick reply! Yeah, I am sure there should be a way to do it, since the data is calculated and stored. I might by skipping something, but my question was how to plot those results at a certain time? Because I know how to plot a variable vs. time, vs. and expression, etc. But I do not know how to make a plot like: y vs. x at t=0.57s Sorry if I misunderstand something in your reply, but I still do not know how to do it. Thanks a lot in advance!
Posted: 1 decade ago 2012/10/15 19:33 JST
I then propose that you study the doc around Data Set and how to create a derived database structure and calculate on thet
Hi I then propose that you study the doc around Data Set and how to create a derived database structure and calculate on thet -- Good luck Ivar
Posted: 1 decade ago 2012/10/15 19:39 JST
Hi, Adrián and Ivar,
As Ivar says, you can select the particular time in the GUI. When you have chosen a time dependent study, at the settings for "Plot", there you can select a particular time (in the "Data"/"Time" list). Nevertheless, you can still select some solution at a particular time through the "at(time, expression)" operator. For instance:
at(5, solid.mises)
gives the von Misses stress at t = 5 s.
Bye,
Jesus.
Hi, Adrián and Ivar, As Ivar says, you can select the particular time in the GUI. When you have chosen a time dependent study, at the settings for "Plot", there you can select a particular time (in the "Data"/"Time" list). Nevertheless, you can still select some solution at a particular time through the "at(time, expression)" operator. For instance: at(5, solid.mises) gives the von Misses stress at t = 5 s. Bye, Jesus.
Posted: 1 decade ago 2012/10/15 20:12 JST
argggg, now I feel very stupid, I already did that in the past with deformations in 3D.
:P
Excuses for the extra question ;)
Thanks a lot!!!
argggg, now I feel very stupid, I already did that in the past with deformations in 3D. :P Excuses for the extra question ;) Thanks a lot!!!
