Misleading advice in tutorial
Posted 2023/03/29 7:43 GMT-4 Wave Optics Version 5.6 3 Replies
Hello, I would like to propose a small correction to your tutorial - it is about model Frequency Selective Surface, Periodic Complementary Split Ring Resonator (Application ID: 78011), https://www.comsol.com/model/frequency-selective-surface-periodic-complementary-split-ring-resonator-78011
I believe, PMLs on both sides are not needed at all there - both ports will deal with it. Here is how one can modify the current model to check my assumption:
- Disable Periodic conditions 2 and 4 in Electromagnetic Waves, Frequency Domain.
- In the main node, Electromagnetic Waves, Frequency Domain, uncheck domains 1 and 5 (which are currently PML). Then the remaining domain selection list will be just 2, 3, and 4.
- For Port 1 and Port 2 in Electromagnetic Waves, Frequency Domain, uncheck Activate slit condition on interior port. This is because these ports are no longer internal - they are at external boundaries of the simulation domain.
That's it, one can run the same studies - with smaller and a bit faster model :) Otherwise - thanks a lot for your tutorials and demos, it really helps a lot!
