pid control and constraining a variable
Posted 2012/10/16 18:29 GMT-4 Fluid & Heat, Heat Transfer & Phase Change, Chemical Reaction Engineering, Materials, Results & Visualization, Studies & Solvers Version 4.3 10 Replies
i'm making a pid control of a heat exchanger and I need to constraining the inlet velocity of fluid. The inlet velocity is calculated by the pid control law, but need to be constrained between 3.5<u<10 How can I make this in comsol? For example:
if u < 3.5 m/s
u = 3.5
if u > 10 m/s
u = 10
best regards,
gustavo
What about using a rect1() or perhaps a Gaussian function to shape your velocity within your limits ?
thanks for help me. I don't explained very well. I need a bether way to make this, my inlet boundary need to be:
if u < 3.5 m/s
u = 3.5
if u > 10 m/s
u = 10
else
u = pid_Control_Law.
In the case that the velocity inlet don't be saturated the value is calculate with a PID controller. You can help with this case?
best regards,
Gustavo
well then cannt you try sometinh like if(u<3.5,3.5,if(u>10,10,yourfunction))
but you shoudl ensure that "yourfunction" is smooth during the transition around 3.5 and 10, i.e. using a rect and a "+u" to get the overall slope along
I made the restrictions in the inlet velocity, but now my model has inconsistent initial values. I don't understant, because without the restrictions the simulation occurs well, but when the inlet velocity turns negative a convergence error occurs. So I think the solution for this is to put a saturation in the inlet velocity boundary (like you said me), but now a initial value error is occuring.
COMSOL proposes all "0" as initial conditions, these are often far from optimum. Perhaps you should first runa stationary case to get your model into a correct starting point, then run a time series thereupon, starting from the stationary initial case (you link the 2nd study to the results of the first one, see the doc)
I made this, the problem with initial conditions is solved, thanks. But know the problem is with the time dependent solver, the solver has convergence error in t = 0. Is this occuring because my initial conditions are wrong?
best regards
Have you checked that all your t=0 BC conditions make sense, not forgotten somewhere a constant value or something. I.e. temperatures in Kelvin "0" K is not a good starting point 0[degC] (or 20) is better
I think the problem is the controller parameter (proportional and integral term), I need to analise better this. I would like to ask you: This model that I need simulate has a industrial scale of 172 m long, but will need a high computational effort and maybe not work. Do you have any ideal how can I simulate this? I need to validate the temperature output of comsol model with the real system and the EDP model that already been done. Completing this step, I will put the PID control law in the inlet boundary condition to tracking the desired temperature and again validate with the real system and the EDP model. I really don't have an idea how to simulate 172 m long. As you have a great experience with this kind of simulation I would like to know your opinion.
obs: currently I just have simulated 3 m long and making some tests with the PID control.
best regards,
Gustavo
All of the above is written based on the mini-course that i attended in the recent Comsol conference. I have not used it myself and anyone using this particular module should be able to tell you better. More details are here:
www.comsol.com/products/pipe-flow/
Good Luck.
best regards
