2012/10/22 15:55 JST
I mostly use Parasolid, or STEP, as STL is not a true 3D CAD coding, but a layered 2D coding
2013/01/29 12:37 JST
Dear Alexander
What have you used finnaly? I have a 3d surface triangular mesh in a .stl file, but I don't know how to make a solid from it, in order to use it as a geometry for my model.
Dear Alexander
2013/02/04 19:57 JST
I have the same problem as well. I can import the triangular surface mesh in geometry sequence. I can convert this to a solid (mostly when i am lucky) but always fail to combine this object with other geometry objects. Simple the difference or union or other operations fail! Do you have any suggestions?
2013/03/21 1:09 JST
Hi!
I managed to find a solution. It is not trivial nor free. We can import the .stl file with +CAD (Simpleware), convert it to a mask and then save/export it as a +ScanIP (simpleware) file. Once in +ScanIP we open the file with the mask and we create a NURBS surface from the mask. We can export the mesh in different formats that Comsol accepts. I tried with .igs extension and it worked.
Some references here:
www.comsol.com/press/news/article/117/
www.comsol.com/products/interfaces/simpleware/
Hi!
2015/07/01 1:36 JST
I use the free software Gmsh to convert .stl surfaces into solid meshes.
First create a volume by Modules->Geometry->Elementary entities->Add->Volume
Then mesh solid by Mesh->3D
Export as .bdf and import in COMSOL under mesh option.
10 years ago
2015/10/24 20:10 JST
Dear Marta,
I've checked your procedure and it worked fine.
Thanks for sharing it here.
Dear Marta,
Walter Frei
COMSOL Employee
10 years ago
2015/10/26 21:45 JST
It is also worth adding to this discussion a brief comment about the upcoming 5.2 release: There will be some significant robustness improvements in STL and mesh import. Not only will these formats import more robustly, you will also be able to perform some further geometric operations on the imported part.
8 years ago
2017/09/09 2:24 JST
I did this step and imported my *.bdf file into Comsol. but still the error is there and cannot creat solid from it
