Problems with the "General Stress-Deformation" Interface for external materials
Posted 2023/05/16 14:50 JST User Interface, Material Models Version 6.0 0 Replies
currently I'm trying to use the external material with the "General Stress-Deformation" type interface. I created all the arrays as mentioned in the "Multiphysics Manual" but I always get the error message "Error in multiphysics compilation. Tensor index out of bounds" which may be related to the interface.
Some informations regarding the material model and the code:
I'm writing in FORTRAN and using the intel FORTRAN compiler with the BIND() command so the code can be read as C. It already worked for the "stress-strain" interface so I don't think this should be the problems root.
I need two sets of internal state variables (or one combined set but I prefer two).
The current COMSOL model is just a simple cube with one element and tension load as recommended.
I attached the model as well as the FORTRAN sniplet and the shared library (for LINUX). If you want to run the simulation you need to re-import the shared library. If you have any solution or advice about modeling in COMSOL please share it (it's my first time using COMSOL). Thanks in advance,
Paul Löps.
Hello Paul Löps
