double parametric sweep in comsol 4.2a
Hi All,
I was wondering if it is possible to define to parametric sweep solvers under one study? for example changing the velocity and temperature at the same time.
thanks
ASAL
5 Replies Last Post 2012/11/06 14:41 JST
Posted: 1 decade ago 2012/10/23 14:28 JST
if you do not change the geometry you can add several parameters to sweep under the Solver node continuation tab, check the doc
Hi if you do not change the geometry you can add several parameters to sweep under the Solver node continuation tab, check the doc -- Good luck Ivar
Posted: 1 decade ago 2012/10/24 7:23 JST
thanks Ivar,
I tried to do so and added two parametric sweeps under one study but it only counts for one of them.
thanks for your help
ASAL
thanks Ivar, I tried to do so and added two parametric sweeps under one study but it only counts for one of them. thanks for your help ASAL
Posted: 1 decade ago 2012/10/24 13:58 JST
I'm not sure if the option is there in 4.2 => Sweep type: Specific combination, or All combination, that might be your issue
Hi I'm not sure if the option is there in 4.2 => Sweep type: Specific combination, or All combination, that might be your issue -- Good luck Ivar
Posted: 1 decade ago 2012/11/06 11:39 JST
thanks Ivar, that has been solved, I was making a silly mistake.
just another question: I put a time dependent water temperature as my inlet temperature at the inlet of pipe but now need to change it to heat flux (W/m) but do not get reasonable answer for that. have you got any hint regarding this issue?
thanks for all your help
ASAL
thanks Ivar, that has been solved, I was making a silly mistake. just another question: I put a time dependent water temperature as my inlet temperature at the inlet of pipe but now need to change it to heat flux (W/m) but do not get reasonable answer for that. have you got any hint regarding this issue? thanks for all your help ASAL
Posted: 1 decade ago 2012/11/06 14:41 JST
if you add a "t" you are adding some multiplier in "seconds" so you whould write 300[K]+4[K/s]*t as t has y default units of [s] the unit issue would be right
But I didnt catch yu heat flux issue, I need to understand in which dimensions you are worling to. You can change your temp boundary to a heat flux boundary and put a time dependent heat flux
Hi if you add a "t" you are adding some multiplier in "seconds" so you whould write 300[K]+4[K/s]*t as t has y default units of [s] the unit issue would be right But I didnt catch yu heat flux issue, I need to understand in which dimensions you are worling to. You can change your temp boundary to a heat flux boundary and put a time dependent heat flux -- Good luck Ivar
