                                2012/10/25 6:00 GMT-4
check the documentation if you need a user-defined port for your model. In many cases you can use a uniform or coaxial port.
Cheers
Edgar
Cheers
Edgar
                                2012/10/25 7:49 GMT-4
                                                    I'm using a user-defined option because i'm simulating an inductor that works in AC with a frequency of about 20kHz. So for that reason i use a impadence boundary condiction for the surface on my inductor and i use a lumped port for the  current generation. I would like to know if there are some standard dimensions for the lumped port that i need to use or one random doesn't change the final result? for example in my model now i'm using hport=96mm and wport=120mm are they corret or other values are more correct?
Nicola
Nicola
                                2012/10/26 2:55 GMT-4
                                                    answers???
                            answers???
                                2012/10/26 3:39 GMT-4
It depends on your model. The port must be much smaller than the wavelength.
