Loss factor
I s it possible to calculate loss factor of a material using comsol?
3 Replies Last Post 2023/07/05 20:02 JST
Posted: 2 years ago 2023/07/04 15:38 JST
Loss factor is a material property, which must be provided to the model from a datasheet or measurements.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Posted: 2 years ago 2023/07/05 17:46 JST
use the PIM Method, you can calculate the loss factor
Posted: 2 years ago 2023/07/05 20:02 JST
PIM (Power Input Method) is an experimental method for determining the loss factor, which as Edgar says, is a material property.
However, when using the PIM method you need to know the strain energy (or the kinetic energy) of the test object. For this purpose you can use a finite element model.
Henrik Sönnerlind
COMSOL
PIM (Power Input Method) is an experimental method for determining the loss factor, which as Edgar says, is a material property. However, when using the PIM method you need to know the strain energy (or the kinetic energy) of the test object. For this purpose you can use a finite element model.
