How to adjust yield surface of Drucker-prager in soil plasticity
Dear All
I am an absolute beginner at COMSOL Multiphysics and I am trying to add soil plasticity in this model, I use Drucker-Prager failure criteria, but many problem existed in this model. I can not use this model for time dependent modeling, because the software always report me mistake: Failed to find consistent initial values, Failed to compute elastoplastic strain variables, last time step is not converged.
Thank you in advance.
2 Replies Last Post 2023/07/05 15:46 JST
Posted: 2 years ago 2023/07/04 15:57 JST
Probable reason: You apply too much load at t=0, or have inconsistent boundary conditions so that no converged solution can be found. Try to apply the loads more gradually.
If it is a problem of finding an initial state for a dynamic analysis, you can use a stationary study step to get appropriate initial conditions.
Henrik Sönnerlind
COMSOL
Probable reason: You apply too much load at t=0, or have inconsistent boundary conditions so that no converged solution can be found. Try to apply the loads more gradually. If it is a problem of finding an initial state for a dynamic analysis, you can use a stationary study step to get appropriate initial conditions.
Posted: 2 years ago 2023/07/05 15:46 JST
Updated: 2 years ago 2023/07/05 15:56 JST
Dear Dr
abourt Knowledgebase entry 1150 discusses this error message.
www.comsol.com/support/knowledgebase/1150/
Do you know how to set "The elastoplastic element fails to evaluate the consistency conditions (due to either loads, displacements, initial stress/strains), and it fails to compute the first elastic-predictor step. That is, your initial state, e.g. assumed in-situ stresses in a geomechanical problem are outside the yield surface." in the first load step?
How can i change the equation view under soil plasticity or change initial stress & strain?
>Probable reason: You apply too much load at t=0, or have inconsistent boundary conditions so that no converged solution can be found. Try to apply the loads more gradually. > >If it is a problem of finding an initial state for a dynamic analysis, you can use a stationary study step to get appropriate initial conditions. Dear Dr abourt Knowledgebase entry 1150 discusses this error message. www.comsol.com/support/knowledgebase/1150/ Do you know how to set "The elastoplastic element fails to evaluate the consistency conditions (due to either loads, displacements, initial stress/strains), and it fails to compute the first elastic-predictor step. That is, your initial state, e.g. assumed in-situ stresses in a geomechanical problem are outside the yield surface." in the first load step? How can i change the equation view under soil plasticity or change initial stress & strain? Thanks
