Derivative with respect to parametric sweep Variable
Posted 2012/11/06 6:22 GMT-5 Results & Visualization Version 4.4 2 Replies
I am having troubles to get a derivative of a Variable which does not directly depend on a sweep parameter.
For Example:
Variable:
A1=intop1(rmm.Az)/Surface
Now I define a sweep parameter called "stage" to have a parametrized Geometry and in every Solution A1 differs. So a plot of "A1" with respect to "stage" is not constant.
What i now want to do is to get the derivative of "A1" with respect to "stage". If I define it as
d(A1, stage)
the result is zero.
Is there a way i can define that derivative?
Thanks in advance
For Example:
Variable:
d(A1, stage)
the result is zero.
Thanks in advance
2 Replies Last Post 2014/12/05 3:49 GMT-5
