Is there an easy way to create a high number of geometric components with a random roughness component?
Hi all,
I am using COMSOL 4.3 to simulate a 2D photonic crystal waveguide made of air holes in a dielectric (using the emw study of the RF module), and I wish to look at how roughness around the holes (as will be inevitable from the eventual fabrication) affects the confinement of light in the waveguide. I have been wondering how to create the surface roughness, and I have come up with two solutions, neither of which are desirable:
1) Using MATLAB, I can create a script which will give the x and y coordinates for an appropriate rough circle (using the random number generator in a clever way). This can be read in to COMSOL as an interpolation curve, and there we have the first rough circle. Now, we need many circles to create the crystal. The easy way out is just to copy the one random rough circle into an array, but this is in no way good enough.
2) Same as above, but with several circles. I.e., creating several txt files from the matlab script, and importing each into an interpolation curve. Ideally this should be done for each 'circle', but it might be way to time-consuming, depending on the size of the crystal. One idea here would be to create enough 'circles', and placing them in a 'random' way, while being careful not to get any periodicity in the placement (i.e., if we have circle 1,2,3, we would not like them placed 1 1 3 2 1 1 3 2, etc...).
Probably both of these solutions are just a substitute for actual knowledge of the geometry part of the simulation tool: There must be an easier way to do this? I would suspect that it is possible to create the geometry in CAD, and importing it to COMSOL: Is there an easier way to do this with CAD software? Any other ideas?
I sincerely appreciate any help on this!
Cheers,
Marius
Edit: It would be extremely nice if there was a way which would let me redefine the roughness (i.e. the expected frequency and amplitude of the error from a perfect circle) so I can find some threshold for when the light will be guided and not... Again, I will be grateful for any help on this one...
8 Replies Last Post 2017/06/05 10:57 GMT-4
Posted: 1 decade ago 2012/11/06 12:19 GMT-5
I don't think there is a nice way of doing it. I found this workaround.
If you use MATLAB rand function, you can use a different seed every time you call the function from COMSOL. For example, you can pass x-coordinate of a circle as a seed. So each circle will have unique shape based on its x-position.
I don't think there is a nice way of doing it. I found this workaround. If you use MATLAB rand function, you can use a different seed every time you call the function from COMSOL. For example, you can pass x-coordinate of a circle as a seed. So each circle will have unique shape based on its x-position.
Posted: 1 decade ago 2012/11/07 8:36 GMT-5
I just started using LiveLink for MATLAB, and this allows me to create similar geometries in batch (by for-looping the appropriate geometry command with different calls, e.g., location and size). Once the geometry is complete I will export it to the desktop version of COMSOL and do the remaining tasks from there, although all can be done using MATLAB (useful for looking at how the model responds to changes in geometry). This is a really nice tool, and I found it quite easy to get into by reading the LiveLinkForMATLABUsersGuide.pdf which is included in the documentation, and probably available online as well...
If anyone else is interested in this type of problem I will be happy to share some minimal example code once I get it up and running!
Cheers,
Marius
I just started using LiveLink for MATLAB, and this allows me to create similar geometries in batch (by for-looping the appropriate geometry command with different calls, e.g., location and size). Once the geometry is complete I will export it to the desktop version of COMSOL and do the remaining tasks from there, although all can be done using MATLAB (useful for looking at how the model responds to changes in geometry). This is a really nice tool, and I found it quite easy to get into by reading the LiveLinkForMATLABUsersGuide.pdf which is included in the documentation, and probably available online as well... If anyone else is interested in this type of problem I will be happy to share some minimal example code once I get it up and running! Cheers, Marius
Posted: 1 decade ago 2014/03/27 0:48 GMT-4
Hey,Marius
I am working on modelling 2D microstructure geometry in Comsol. I want to create abuot 500 random circle. Could you give me some suggestions?
Thank you very much.
yuliang
Hey,Marius I am working on modelling 2D microstructure geometry in Comsol. I want to create abuot 500 random circle. Could you give me some suggestions? Thank you very much. yuliang
Giovanni Giansiracusa
Posted: 9 years ago 2016/10/31 7:45 GMT-4
Hey,Marius
yuliang
Hi, did you manage to do it? I have the same problem. Let me know
[QUOTE] Hey,Marius I am working on modelling 2D microstructure geometry in Comsol. I want to create abuot 500 random circle. Could you give me some suggestions? Thank you very much. yuliang [/QUOTE] Hi, did you manage to do it? I have the same problem. Let me know
Jeff Hiller COMSOL Employee
Posted: 9 years ago 2016/10/31 15:39 GMT-4
Hello Giovanni,
Marius's solution of using LiveLink for MATLAB is a good one. Alternatively, you could use an app to generate this geometry (same idea, different programming language: Java instead of MATLAB).
Hello Giovanni, Marius's solution of using LiveLink for MATLAB is a good one. Alternatively, you could use an app to generate this geometry (same idea, different programming language: Java instead of MATLAB). Best, Jeff
Posted: 9 years ago 2017/02/24 8:02 GMT-5
Hey Marius
I am working on similar problem and I would really appreciate if you can share your example code for generating a random distribution of pores in a geometry.
Thanks!
Hey Marius I am working on similar problem and I would really appreciate if you can share your example code for generating a random distribution of pores in a geometry. Thanks!
Posted: 9 years ago 2017/02/24 8:33 GMT-5
See Walter's and my posts in this thread:
www.comsol.com/community/forums/general/thread/123442
There is also a recorded webinar that shows how to generate a geometry algorithmically with the Application Builder:
www.comsol.com/events/webinar/Automating-Preprocessing-and-Postprocessing-with-the-Application-Builder-Webinar-23741
See Walter's and my posts in this thread: https://www.comsol.com/community/forums/general/thread/123442 There is also a recorded webinar that shows how to generate a geometry algorithmically with the Application Builder: https://www.comsol.com/events/webinar/Automating-Preprocessing-and-Postprocessing-with-the-Application-Builder-Webinar-23741 Best, Jeff
Posted: 8 years ago 2017/06/05 10:57 GMT-4
See this new blog: www.comsol.com/blogs/how-to-generate-random-surfaces-in-comsol-multiphysics/
See this new blog: https://www.comsol.com/blogs/how-to-generate-random-surfaces-in-comsol-multiphysics/ Best, Jeff
