setting initial temperature for a heat transfer and fluid flow module
Posted 2023/08/01 13:52 GMT-4 Fluid & Heat, Modeling Workflow, Physics Interfaces Version 6.1 1 Reply
I am currently running a simulation on comsol where a lithium ion battery is cooled using a water cooled jacket where the jacket is made of aluminum. I used the lumped battery physics to model the battery and discharged it at 4C. I additionally used the heat transfer in solids and fluids physics as well as the laminal flow physics. I kept the ambient temperature and the batteries initial temperature at 313.15 kelvin and the water (coolant) temperature at the inlet of the jacket as 293.15 Kelvin. However after i ran a time dependent simulation for 900 seconds, the results gave me a strange plot. When I checked the battery temperature with respect to time, the graph started from a temperature of 293.15 kelvin, even though the batteries initial temperature was set to 313.15 kelvin. There is cooling however, the results would make sense if the battery temperature at time 0 was shown as 313.15 kelvin since that is what the initial condition was set to. How do i resolve this issue so as to get a temperature vs time graph which gives a temperature of 313.15 Kelvin at time 0
