Gaussian focused beam, 4.2a
Dear All,
I have issue. I have silver block on the glass.
I want to illuminate it from the bottom (so light first propagate through the glass),
but I want to illuminate it with Gauss focused beam (I do that for the scattered field).
Do you maybe know some equation of Gauss focused beam (in 3D)?
Cheers and thanks
2 Replies Last Post 2012/11/09 23:28 JST
Posted: 1 decade ago 2012/11/09 21:36 JST
it depends on how many physics, if you are simulating the EM field, you could use the Definitions - gaussian function to modulate the spatial intensity distribution in X-Y (assuming you are propagating along Z) but then to get it to "focus down, you would need to add a phase term (as function of X-Y) to map the curvature at the entrence of your "inlet" boundary. By the way the simplest is probably to add a cylindrical coordinate along your beam axis and express everything in this coordinate frame, this reduces one dimension for the functions to define
Hi it depends on how many physics, if you are simulating the EM field, you could use the Definitions - gaussian function to modulate the spatial intensity distribution in X-Y (assuming you are propagating along Z) but then to get it to "focus down, you would need to add a phase term (as function of X-Y) to map the curvature at the entrence of your "inlet" boundary. By the way the simplest is probably to add a cylindrical coordinate along your beam axis and express everything in this coordinate frame, this reduces one dimension for the functions to define -- Good luck Ivar
Posted: 1 decade ago 2012/11/09 23:28 JST
Thanks for advice.
I will try on that way.
Cheers
[QUOTE] Hi it depends on how many physics, if you are simulating the EM field, you could use the Definitions - gaussian function to modulate the spatial intensity distribution in X-Y (assuming you are propagating along Z) but then to get it to "focus down, you would need to add a phase term (as function of X-Y) to map the curvature at the entrence of your "inlet" boundary. By the way the simplest is probably to add a cylindrical coordinate along your beam axis and express everything in this coordinate frame, this reduces one dimension for the functions to define -- Good luck Ivar [/QUOTE] Thanks for advice. I will try on that way. Cheers
