Error correction
During simulation of grating structure, we got error: Division by zero. - Function: / Failed to evaluate expression. - Expression: abs(comp1.ewfd.port1.Pin/comp1.ewfd.Pmode_1) Failed to evaluate variable. - Variable: comp1.ewfd.tEmodex_1 - Defined as: sqrt(abs(comp1.ewfd.port1.Pin/comp1.ewfd.Pmode_1))comp1.ewfd.tE0modex_1 Failed to evaluate expression. - Expression: nojac(comp1.ewfd.tEmodex_1) Failed to evaluate variable. - Variable: comp1.ewfd.PortConstrx - Defined as: (1+if((abs(comp1.ewfd.beta_1)>((1.0E-7comp1.ewfd.intport1(comp1.ewfd.k))/comp1.ewfd.Area_1))&&((abs(arg(comp1.ewfd.beta_1)unit_rad_cf)<=(0.25pi))||(abs(arg(comp1.ewfd.beta_1)unit_rad_cf)>=(pi0.75))),comp1.ewfd.S1x,0))*nojac(comp1.ewfd.tEmodex_1) Failed to evaluate expression. - Expression: comp1.ewfd.tEx-comp1.ewfd.PortConstrx
how to solved it?
1 Reply Last Post 2023/08/13 7:04 JST
Posted: 2 years ago 2023/08/13 7:04 JST
This (admittedly not very helpful) error message typically appears when something about the simulation is not completely specified.
For more detailed help post your (reduced) model and perhaps someone who also has that module licensed can help out.
This (admittedly not very helpful) error message typically appears when something about the simulation is not completely specified. For more detailed help post your (reduced) model and perhaps someone who also has that module licensed can help out.
