Import geometry from Matlab into Comsol
First of all, I want to emphasize that I am a beginner with Comsol.
I am trying to import a geometry generated with Matlab into Comsol in order to study the wave propagation in this geometry.
My geometry is simply a n*n matrix, with 2 values : 0 and 1. The value 1 is the material and the value 0 is the air inside the material.
How can I import this matrix into Comsol to work with ?
Thank you for helping out.
2 Replies Last Post 2013/02/06 5:14 JST
Hello Olivier Mesnil
Saeid Norouzi Apourvari
Posted: 1 decade ago 2013/01/30 10:57 JST
Hi Oliver,
I had the same problem as you have and I did onething which I beleive is not the right way but worked. What I did, I visualized the 2D structure in MATLAB using "imagsc" command and then saved the figure as .png file. Then I used an online converter to convert the .png image into the .dxf format which is acceptable by COMSOL.
Hope this helps you,
Good luck,
saeid
Hi Oliver, I had the same problem as you have and I did onething which I beleive is not the right way but worked. What I did, I visualized the 2D structure in MATLAB using "imagsc" command and then saved the figure as .png file. Then I used an online converter to convert the .png image into the .dxf format which is acceptable by COMSOL. Hope this helps you, Good luck, saeid
Posted: 1 decade ago 2013/02/06 5:14 JST
Hi Oliver,
Good luck,
saeid
Hi Saeid,
Thank you for this answer ! I had lost hope to do it by this way but actually it works !
Thank you again.
Olivier.
[QUOTE] Hi Oliver, I had the same problem as you have and I did onething which I beleive is not the right way but worked. What I did, I visualized the 2D structure in MATLAB using "imagsc" command and then saved the figure as .png file. Then I used an online converter to convert the .png image into the .dxf format which is acceptable by COMSOL. Hope this helps you, Good luck, saeid [/QUOTE] Hi Saeid, Thank you for this answer ! I had lost hope to do it by this way but actually it works ! Thank you again. Olivier.
