Kristian Ejlebjærg Jensen
COMSOL Employee
2 years ago
2023/09/29 21:07 JST
The sensitivity analysis needed for topology optimization happens automatically, so you do not need to do anything.
I do not understand the question. What do you mean by "proper topology"? The optimized design depends on several non-dimensionless number (not only w). Both the Darcy and Péclet number can affect the result.
Some problems will benefit from using movelimits with MMA. This setting is available on the topology optimization study step.
Kristian E. Jensen
Technical Product Manager, Optimization
Kristian E. Jensen
2 years ago
2023/10/01 16:29 JST
Dear Jensen
Thank you very much for your kind instruction.
A proper topology optimization implies that the objective function tends to flow or heat transfer smoothly as the weight factor w is increasing or decreasing. When w=0.5, there should be balanced flow and heat transfer, and in my optimization process, the topology result at this point is clearly more inclined to flow. This leads to a simpler overall topology after w>0.5.
At the same time, I am a bit confused about the effect of Pe number on the results. Does it mean that with a larger Pe number, the overall forced motion is more inclined to convection than diffusion?Or how do I need to adjust the Pe number. Also how do the movement limits need to be set in the MMA method, is there an official Comsol case, thanks.
Best regards, Gavin.
Dear Jensen
COMSOL Employee
2 years ago
2023/10/02 22:44 JST
You can set the movelimit on the topology optimization study step, but I do not think it will help.
The topology optimization minimizes the objective while respecting the constraints. I guess you have a flow driven setup in this case and use the pressure loss as one of the objectives. You then expect to get a similar objectives for w=0.5, but the problem is nonlinear so there is no reason that this should happen. If you like, you can use pressure driven setup instead to avoid the w alltogether.
The results you show seem to reproduce the behavior presented in the paper in a qualitative sense. The remaining differences can be due to many things: variations in numerical and/or physical parameter or perhaps a different mesh/discretization.
Kristian E. Jensen
Kristian E. Jensen
