Operators not Allowed in User Defined Functions
I am trying to solve a multidimensional time-dependent problem in Comsol using the Coefficient Form PDE framework. My question is related to defining the initial condition, however. I would like to set: When I try to do this using the sum() operator as described in this article, I get the error "Operators not allowed in user defined functions". My question is how else can I achieve this? Of course I know I could write this function out term-by-term but I would ideally like to take N to be quite large which makes that infeasible (or at least very tedious). Is there anyway around this?
2 Replies Last Post 2023/10/10 13:07 GMT-4
Dave Greve Certified Consultant
Posted: 8 months ago 2023/10/10 12:47 GMT-4
Updated: 8 months ago 2023/10/10 12:46 GMT-4
Since your h function appears to be a Fourier series, what is the function that it is a Fourier series for? Maybe you can use that directly as an initial condition.
Reminds me of the time I inserted a series expansion of a Bessel function, not realizing that Bessel functions were already in Comsol.
By the way- I believe your sum is over i not n??
Since your h function appears to be a Fourier series, what is the function that it is a Fourier series for? Maybe you can use that directly as an initial condition. Reminds me of the time I inserted a series expansion of a Bessel function, not realizing that Bessel functions were already in Comsol. By the way- I believe your sum is over i not n??
Posted: 8 months ago 2023/10/10 13:07 GMT-4
Mark,
an alternative may be to define a variable instead of the function. Quite a bit more complex is an external function using a DLL that needs to be coded in C.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Mark, an alternative may be to define a variable instead of the function. Quite a bit more complex is an external function using a DLL that needs to be coded in C. Cheers Edgar
