Static Analysis Multibody Dynamics Module
Posted 2023/10/10 2:58 GMT-4 Studies & Solvers, Structural Mechanics, Structural Dynamics Version 6.1 1 Reply
Dear all,
I am trying to do a steady-state analysis of a rigid body geometry with the Multibody Dynamics Module (MDM).
I set up a geometry of rigid bodies, defined all attachments and approriate hinges following the Workflow of the double pendulum tutorial. Now doing the analysis I get, that I have to constrain the bodies/hinges so they wont move (see linked thread).
However, I cannot find the correct way to do that. Constraining just the hinges or just the rigid bodies, I cannot achieve convergence or get after some iteration s a singular matrix error. Constraining both leads to a singular matrix error even before the computation starts.
The dof overview shows for all cases 0 net dofs and the respective number of net constraints is always larger than 0. Also, I find the dof analysis rather confusing. Shouldnt I be able to solve the set of equations, if the net dof is zero and therefore the system is neither under- nor overdetermined?
Any help, insights or advice you can provide is greatly appreciated.
André.
Ps: I unfortunately cannot share the model file due to security issues since this is for a work related project.
