Changing the position of an imported geometry in the COMSOL coordinate system
Posted 2012/11/21 10:05 GMT-5 Geometry 12 Replies
I'm trying to change the positions of two imported geometries in the COMSOL coordinate system. Unfortunately, after scaling them, they are not placed in the point of origin but somewhere else.
Changing positions of geometries created in COMSOL is no problem but as I am dealing with imported geometries I have difficulties at that point. Does anyone know how to accomplish that?
Thank you.
but cant you "just" "move" also an imported geometry ?
Just right click Geometry and the select Move under Transforms. That was a little tricky as I expected to find the Move button right away and under Transforms...
I know how to use move function, however, I cannot find out the coordinates of edges of my rectagular geometry.
You can use the Measure button to determine the coordinates of vertices in your geometry. See Reference Manual, version 5.2a, pages 393-394. All manuals are accessed through File > Help > Documentation.
Hello Seunghun,
Hi Jeff,
Is it possible to modify/edit an imported geometry in COMSOL. For example, if I import .mphbin file which has 2 concentric cylinders and I want to change the size (height or radius) of those cylinders. Is it possible? If yes, please let me know. Thank you.
Ranjha
You would not import a .mphbin file in that case. Instead you'd use "insert sequence" and point to the .mph file which contains the parametrized geometry.
Hi Qasim,
Hi Jeff,
Thank you very much for the help. It means its always better to save your geometry as .mph file rather than .mphbin file. I hope COMSOL would fix this in the next release. This would be helpful in case someone wants to do parametric analyses for geometric dimensions or in a case where you are creating a complex geometry want to save and resume it later.
Best
Qasim
Each format has its relative benefits and drawbacks as far as geometry transfer is concerned. One benefit of the mphbin format is its portability between versions, i.e. you can create a geometry in a recent version of COMSOL, save it as an mphbin file and then import it into an older version of COMSOL Multiphysics. Another benefit of the mphbin format is the smaller file size. On the other hand, the mph format retains the history of steps needed to create a geometry and its parametrization.
Yes, portability is a great advantage. However, addition of an option to save and reload the geometry as sequence would be a great help too. A single geometry file without mesh should still be of small size.
Thank you.
Qasim
I have another question. Is it possible to export the solution (spreadsheet or sectionwise) to Tecplot?
Best
Qasim
Since this latest question is unrelated to this thread, please consider starting a new thread. You are more likely to get responses from Discussion Forum users if your question is in a thread with a related subject line.
