bringing B-spline surfaces into COMSOL
Posted 2012/11/23 16:51 GMT-5 Geometry Version 4.3 0 Replies
The optimal thing would be to take the knot vectors and control points found in MATLAB and give them directly to COMSOL, to use to define its surface. (I defined my B-spline surfaces using "The NURBS book," which was the reference I was given by a COMSOL technician, so I believe my splines to be defined in a way just about identical to COMSOL's. There is thus little reason to believe that COMSOL's parametric surface would be significantly different from the one I start with, if I could just pass on the same information). I have not found a way to do this though. Does anyone have any experience with bringing B-spline surfaces into COMSOL or suggestions on how to make this process more efficient?
Thanks in advance,
Martin
Hello Martin Bouda
