Auxiliary sweep - parameter list values
Hi All,
I want to run a fluid flow/heat transfer problem with a boundary condition of 90 psi. The model only converges at 0.15 psi, so I am going to use an auxiliary sweep to ramp up the pressure values. Just wondering if anyone has a suggestion for what the parameter list values could be.
As a start I tried 0.15, 0.5, 1 which failed because the minimum step was too large, so I went with 0.15, 0.25, 0.5 which worked. However to get values all the way up to 90 will be time consuming, because the model takes a few minutes to test each value. Is there a more efficient way to figure this out?
1 Reply Last Post 2023/11/24 16:21 GMT-6
Posted: 3 years ago 2023/11/24 16:21 GMT-6
Updated: 3 years ago 2023/11/24 16:13 GMT-6
Ignore this I solved it:)
