How to change equation during a transient solution in V4.3
Hello everybody,
I am simulating a transient solution by using transport of dilute species. I would like to change the equation during a transient solution and use the initial value of simulation 2 from last time step of simulation 1, please help me.
The methodology I use is :
1. I run simulation 1 with the equation 1, 3, 4, 5 and 6
2. I run simulation 2 with the equation 2, 3, 4, 5 and 6
How to do it ?
Thank you very much.
Piyaporn
2 Replies Last Post 2012/12/05 4:35 JST
Posted: 1 decade ago 2012/12/05 4:01 JST
check the doc on the solvers, and the tabs for solver initial values ("Values of Dependent variables"), and get those of study 2 to point to study 1
or if both sequences are under the same study1, then get step2 to point to step1
Then use the step tab "Physics and Variables" selection to disable enable the desired BCs
Hi check the doc on the solvers, and the tabs for solver initial values ("Values of Dependent variables"), and get those of study 2 to point to study 1 or if both sequences are under the same study1, then get step2 to point to step1 Then use the step tab "Physics and Variables" selection to disable enable the desired BCs -- Good luck Ivar
Posted: 1 decade ago 2012/12/05 4:35 JST
Thank you very much Ivar
