Field Enhancement
Gopika Gopalakrishnan
What is the procedure for getting the field enhancement of a nanogap?
1 Reply Last Post 2024/02/08 9:55 GMT-5
Posted: 3 years ago 2024/02/08 9:55 GMT-5
Updated: 3 years ago 2024/02/08 9:59 GMT-5
I don't know anything specific about nanogaps, but if/when I want to compute the electric field on/around some pointy geometric entity, I employ a relatively fine mesh on the boundary, compute the fields, and then inspect/plot the fields in that region. Meshing makes a difference here. If you need high confidence, keep refining the mesh, constraining it to be high quality, and re-running the model until the field value at the points/edges/surfaces in question stops changing too much. If you have the time and memory, then maybe consider a higher element discretization (e.g., cubic or quadratic instead of linear). You may also see differences in values plotted if you turn on/off various degrees of smoothing in the plot. Inspect the plot in detail without smoothing, if you want to check if your mesh seems sane/fine enough. Strong gradients in field between adjacent mesh elements may be cause for additional attention, and likely finer meshing, there. You don't have to mesh everywhere super-finely, just where the (if serious) field enhancement occurs. And you can usually guess where that is going to be (or is likely to be) in advance. I also sometimes employ probes (surface or volume) to quantify or locate maximum fields, since the max field is often of interest when studying field enhancement. There are also analytic approximations / sanity checks you can apply (you know, the sorts of things people used to do, such as conformal mapping, before these wonderful codes and computers made our lives so easy).
I don't know anything specific about nanogaps, but if/when I want to compute the electric field on/around some pointy geometric entity, I employ a relatively fine mesh on the boundary, compute the fields, and then inspect/plot the fields in that region. Meshing makes a difference here. If you need high confidence, keep refining the mesh, constraining it to be high quality, and re-running the model until the field value at the points/edges/surfaces in question stops changing too much. If you have the time and memory, then *maybe* consider a higher element discretization (e.g., cubic or quadratic instead of linear). You may also see differences in values plotted if you turn on/off various degrees of smoothing in the plot. Inspect the plot in detail without smoothing, if you want to check if your mesh seems sane/fine enough. Strong gradients in field between adjacent mesh elements may be cause for additional attention, and likely finer meshing, there. You don't have to mesh everywhere super-finely, just where the (if serious) field enhancement occurs. And you can usually guess *where* that is going to be (or is likely to be) in advance. I also sometimes employ probes (surface or volume) to quantify or locate maximum fields, since the max field is often of interest when studying field enhancement. There are also analytic approximations / sanity checks you can apply (you know, the sorts of things people used to do, such as conformal mapping, before these wonderful codes and computers made our lives so easy).
