Initial condition for time dependent study
Posted 2012/12/12 7:00 GMT-5 5 Replies
I'm trying to model free vibration of a small PZT cantilever (MEMS). I need to apply some initial conditions on displacement in a time dependent study. How can i do it?
Andrea
you can for example apply a boundary load of the type f0*sin(2*pi*freq*t) or better if you have a continuous sinus type laod, use the harmonic development with the frequency domain solver and apply a load of amplitude F0, and define the frequency freq in the frequency domain solver node. This gives ou amplitudes as responses
thanks for the answer but I need only to apply an initial condition like w(t0)=1 on the end face of my cantilever and not a "sin boundary load" ( I've just create it with success :-) )..
if you impose a displacement at launch (t=0) and let it go, i.e. wit a step() from 1 to 0 times your value, you will have someproblems, as its not only the tip of the canteliever that should be displaced, but the full model.
Then I believe it's better to start with a stationary solver case, with your load or displacement BC, get the solution, store it and then do a times series from the stationary solution, using it as the seady state initial conditions, and in your time series solver you disable the boundary displacement / load.
thanks for the answer but I have another problem: if I put a buondary condition like w(t0)=0 in the step1(stationary) of my time dipendent analysis how can i disable that condition in the step2(time dipendent) ?
Andrea
if you solve for a stationary solver first, you can
a) enable and disable different BC from the solver node (latest versions)
b) you can also use step(t[1/s]) functions (and adding in a global Parameter t=0[s] for the stationary case) to set a given BC to "0" (i.e. heat flux etc)
But fixed BC might have to be "disabled/enabled" per solver study node and cannot always be easily "switched" with a Boolean (t==0)
Suggested Content
- FORUM Start Time Dependent Study With Initial Conditions From A Time Dependent Solution
- KNOWLEDGE BASE Solving time dependent models with inconsistent initial values
- FORUM Time Dependent Study, Initial Condition Setup
- BLOG How to Simulate the Carrier Dynamics in Semiconductor Devices
- FORUM Initial Value Erron in Time Dependent Study
