Spatially-varying boundary condition (electric potential)
Hi all!
I am using the Electrostatics package and need to define a surface with a linearly-varying electric potential that depends on one dimension of the model (e.g. V(x,y) = Kx). I tried to define a formula for the potential as suggested in
the thread www.comsol.com/community/forums/general/thread/662/ , but after successfully defining the formula I was unable to use it as the potential in an "Electric Potential" constraint (field "Vo"). Any ideas on how can this be done?
Thanks for any help!
Jorge.
2 Replies Last Post 2012/12/19 0:31 JST
Posted: 1 decade ago 2012/12/18 23:34 JST
Normally you can write out in your electric potential field
V0*x/Length
with Length a Parameter for normalisation in units of length (metres), or just
V0*x[1/m]
the latter with V0 given in Volts per meter (implicit) or V0*x with units of V0 explicitly set to [V/m]
Hi Normally you can write out in your electric potential field V0*x/Length with Length a Parameter for normalisation in units of length (metres), or just V0*x[1/m] the latter with V0 given in Volts per meter (implicit) or V0*x with units of V0 explicitly set to [V/m] -- Good luck Ivar
Posted: 1 decade ago 2012/12/19 0:31 JST
Dear Ivar,
it works like a charm!!! THANKS SO MUCH, you just saved our day! :)
Jorge.
Dear Ivar, it works like a charm!!! THANKS SO MUCH, you just saved our day! :) Jorge.
