how mark a line/point/surface in an animation/figure
How to keep track of and mark a line/point/surface with known x,y,z as red in an animation/figure under results to manifest that line/point/surface?
2 Replies Last Post 2024/03/26 1:23 GMT-4
Posted: 3 years ago 2024/03/20 9:01 GMT-4
If you want to trace a point at a certain location, use a Point Trajectories plot.
If you want to track a certain Point/Line/Surface, add a plot of the same type, set the color to Uniform Red, and add a Selection containing only the intended object. You can then add a Deformation node to make it follow the structural displacements.
Henrik Sönnerlind
COMSOL
If you want to trace a point at a certain location, use a *Point Trajectories* plot. If you want to track a certain Point/Line/Surface, add a plot of the same type, set the color to *Uniform* *Red*, and add a *Selection* containing only the intended object. You can then add a *Deformation* node to make it follow the structural displacements.
Posted: 3 years ago 2024/03/26 1:23 GMT-4
thank you very much Dr Sönnerlind
