Composite material
Is there anyone who can help me add a plane weaved bidirectional fibre in COMSOL.
3 Replies Last Post 2024/05/06 5:21 GMT-4
Amit Suresh Patil COMSOL Employee
Posted: 3 years ago 2024/04/09 6:59 GMT-4
Hi Lokesh,
There is a built-in geometry part available for a bidirectional plain weave fiber composite in the part libraries. You can customize the existing part as per your needs. Please check Part Libraries >> Comsol Multiphysics >> Unit Cells and RVEs >> Fiber Composites folder.
Regards Amit
Hi Lokesh, There is a built-in geometry part available for a bidirectional plain weave fiber composite in the part libraries. You can customize the existing part as per your needs. Please check Part Libraries >> Comsol Multiphysics >> Unit Cells and RVEs >> Fiber Composites folder. Regards Amit
Posted: 3 years ago 2024/05/03 2:03 GMT-4
Hi Lokesh,
Regards Amit
Thanks Sir
>Hi Lokesh, > >There is a built-in geometry part available for a bidirectional plain weave fiber composite in the part libraries. You can customize the existing part as per your needs. Please check Part Libraries >> Comsol Multiphysics >> Unit Cells and RVEs >> Fiber Composites folder. > >Regards >Amit Thanks Sir
Posted: 3 years ago 2024/05/06 5:21 GMT-4
Updated: 3 years ago 2024/05/06 8:44 GMT-4
Hi Sir I am getting doubt on converting a "Single Layer Lamina" of fibre and epoxy into a "Double Layer Laminate". Can you tell me the procedure to make a laminate from a layer? Example : I have a bidirectiona fibre and epoxy i had model it in COMSOL and made a sibgle layer composite but i have to add multi layer i.e more than one (two, three,four,five.six,seven.eight and so on). So how i can go in COMSOL. Kindly help me if possible.
