Josh Thomas
Certified Consultant
2013/01/07 8:44 GMT-5
Mohamed,
Simply type: 0.29*T in the edit field for D. Anywhere you can enter values in COMSOL you can also enter expressions.
Josh Thomas
AltaSim Technologies
Mohamed,
Josh Thomas
2013/01/07 8:52 GMT-5
Thank you very much Josh.
2013/01/07 9:53 GMT-5
Hi Josh,
ok for the expression but how can I insert the tempreture interval [900 to 1200] ?
best regards
Mohamed
Hi Josh,
best regards
Mohamed
2013/01/08 1:04 GMT-5
define a parameter, and either use the Solver "continuation tab, or add a Parametric sweep node before your solver node (right click the study node) and define your parameter to get your value following your sequence, then adapt the BC or local definition for "T" such that it uses the Parameter
2013/01/08 5:53 GMT-5
Thx Ivar for this response.
Have u an example that explain this steps ? If not, can you please explain with more details ? I can't find the solver "continuation tab"
best regards
best regards
2013/01/08 10:43 GMT-5
what about using the help ? try search for "Parametric Study" ;)
