Using the results of iteration as input to next iteration?
I am using Comsol to calculate cooling in oil-paper isolation. The iteration is slow and does not converge easily. I have reduced the damping factor to achieve a reasonable solution.
It would be fine to be able to use the results of the previous solution as start values of a new iteration process. In this process I can reduce the damping factor and achieve more accurate results.
Is there a way to do this?
Thanks in advance
Kamil
2 Replies Last Post 2013/01/08 17:13 JST
Posted: 1 decade ago 2013/01/08 17:11 JST
check your node: "Study - Solver configuration - Dependent variables" and the related doc/help
Hi check your node: "Study - Solver configuration - Dependent variables" and the related doc/help -- Good luck Ivar
Posted: 1 decade ago 2013/01/08 17:13 JST
Thank you Ivar for your quick replies.
Kamil
Thank you Ivar for your quick replies. Kamil
