Accessing the outlet value to apply in the inlet boundary
Posted 2013/01/08 17:47 JST Heat Transfer & Phase Change, Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions 2 Replies
I need to set up the inlet boundary condition (temperature) in the conjugate heat transfer analysis with larminar flow. However T of inlet (fluid) should be like this:
Tin = Tout + 3 K (at every time step)
The scenario is that the water from outlet is boiled and then re-injected into inlet.
What variable do I use to get outlet temperature?
Is there any function to access boundary values in the variable expression?
Thanks.
Chulho
Hello Chulho Lee
