Kristian Ejlebjærg Jensen
COMSOL Employee
2 years ago
2024/05/29 6:41 GMT-4
Updated:
2 years ago
COMSOL does not support integer optimization. IPOPT will change controls even though the sensitivity is zero, but in most situations, you can just fix the integer and perform a sweep over the optimization. It sounds like you only have a single integer parameter, so this ought to be a viable strategy.
Kristian E. Jensen
Technical Product Manager Optimization
Kristian E. Jensen
2 years ago
2024/05/29 11:38 GMT-4
Updated:
2 years ago
2024/05/29 11:40 GMT-4
Thank you for the reply, I will try that.
Is the incrementation of each parameter constant over the optimisation ? if so I could maybe find a scale factor that makes the step be 1
COMSOL Employee
1 year ago
2024/06/11 4:13 GMT-4
Updated:
1 year ago
2024/06/11 15:02 GMT-4
You can specify the increment in the Parametric Sweep, i.e. range(1,1,10) sweeps the value from 1 to 10 in steps of 1.
Kristian E. Jensen
Kristian E. Jensen
