How to extract fluid domain from the given solid domain
If I have a complicated geometry, and i want to do the fluid flow analysis inside that geometry, how will I cretae a fluid domain from the given solid geometry?
3 Replies Last Post 2024/06/06 8:22 GMT-4
Jeff Hiller COMSOL Employee
Posted: 2 years ago 2024/06/05 8:46 GMT-4
Hello Lakshmi sree,
You can use the "Cap Faces' capability. See this old post, for instance, for more detail.
Jeff Hiller
Hello Lakshmi sree, You can use the "Cap Faces' capability. See [this old post](https://www.comsol.com/forum/thread/241541/create-cfd-mesh-from-cad-geometry?last=2019-08-27T17:39:06Z), for instance, for more detail. Best regards, Jeff
Posted: 2 years ago 2024/06/06 1:26 GMT-4
hello Jeff Hiller, Thank you for the support. Once I create the fluid geometry from the structural geometry, how do i delete the structural geometry, Because I want to work only with fluid geometry
Thanks and regards Lakshmi sree P
hello Jeff Hiller, Thank you for the support. Once I create the fluid geometry from the structural geometry, how do i delete the structural geometry, Because I want to work only with fluid geometry Thanks and regards Lakshmi sree P
Posted: 2 years ago 2024/06/06 8:22 GMT-4
You should be able to delete it like you would delete any other geometry entity, nothing special.
Jeff Hiller
You should be able to delete it like you would delete any other geometry entity, nothing special. Jeff
