Can you import data into Comsol 3.5?
I'd like to import data into Comsol 3.5, for example, the refractive index of a material. The data are in such a format:
wavelength(nm) , n
300 , 2.5
301 , 2.49
302 , 2.48
303 , 2.47
etc.
I'd like to import the data as a scalar variable, so that Comsol can interpolate the refractive index n as a function of wavelength. Is it possible to do so in Comsol 3.5?
Thanks.
5 Replies Last Post 2013/01/15 6:57 JST
Posted: 1 decade ago 2013/01/15 4:21 JST
Ray,
Use the following steps:
1. Options>Functions
2. Click New
3. In the New Function window, define function name, click Interpolation radio button, and select File from Used data from selection list
4. Click Browse button to locate file with your data for refraction index.
5. Click OK
Sergei
Ray, Use the following steps: 1. Options>Functions 2. Click New 3. In the New Function window, define function name, click Interpolation radio button, and select File from Used data from selection list 4. Click Browse button to locate file with your data for refraction index. 5. Click OK Regards, Sergei
Posted: 1 decade ago 2013/01/15 5:06 JST
Thank you so much! You made my day :)
Posted: 1 decade ago 2013/01/15 6:23 JST
I have another question: I defined two functions: n and k, which are the real and imaginary parts of the refractive index. The complex refractive index is expressed as: n+ki. How do I use n+ki as a variable? I tried n+ki, n+k*i, n-i*k, none of them worked. Comsol simply doesn't recognize the combined complex number. How do I combine these two functions into one complex function and use it in Comsol?
Thank you.
I have another question: I defined two functions: n and k, which are the real and imaginary parts of the refractive index. The complex refractive index is expressed as: n+ki. How do I use n+ki as a variable? I tried n+ki, n+k*i, n-i*k, none of them worked. Comsol simply doesn't recognize the combined complex number. How do I combine these two functions into one complex function and use it in Comsol? Thank you.
Posted: 1 decade ago 2013/01/15 6:43 JST
Ray,
Under Options>Global Expressions, define variable
complex_n=n(lambda)+j*k(lambda)
and use variable “complex_n” as needed anywhere.
If you need real part of this variable, then real(complex_n)=n(lambda).
Similarly, imag(complex_n)=k(lambda).
Sergei
Ray, Under Options>Global Expressions, define variable complex_n=n(lambda)+j*k(lambda) and use variable “complex_n” as needed anywhere. If you need real part of this variable, then real(complex_n)=n(lambda). Similarly, imag(complex_n)=k(lambda). Regards, Sergei
Posted: 1 decade ago 2013/01/15 6:57 JST
Thank you, Sergei. It worked. You are so wonderful! :)
