Why auxiliary sweep show the same results when sweeping 2 parameters?
When I use an auxiliary sweep in topology optimization to sweep volume constraint and projection slope, my sweep goes like:
  • fv: 0.8, 0.7, 0.6
  • beta: range(1, 5, 41)
I thought the sweep should proceed like this:
  1. fv = 0.8, beta = 1: Run topology optimization until the objective reaches the maximum. This might take about 5 steps to obtain an optimized structure.
  2. Update beta: fv = 0.8, beta = 6
fv = 0.8, beta = 11
fv = 0.8, beta = 16
fv = 0.8, beta = 41
  1. Update fv to 0.7:
fv = 0.7, beta = 1
fv = 0.7, beta = 6
fv = 0.7, beta = 11
fv = 0.7, beta = 16
fv = 0.7, beta = 41
  1. Update fv to 0.6:
fv = 0.6, beta = 1
fv = 0.6, beta = 6
fv = 0.6, beta = 11
fv = 0.6, beta = 16
fv = 0.6, beta = 41
The simulation should finish after this sequence. However, when I check the obtained data, why are the data values for fv = 0.8, 0.7, and 0.6 all the same?
2 Replies Last Post 2024/08/29 8:41 GMT-5
Kristian Ejlebjærg Jensen COMSOL Employee
Posted: 2 years ago 2024/06/25 6:05 GMT-5
Hi Bruce
It sounds like you want to use continuation, but the auxilliary sweep is for inner sweeps/load cases, while you need an outer sweep to do continuation. You might want to have a look at bracket_topology_optimization_stl in the Application Library.
Kristian E. Jensen,
Technical Product Manager, Optimizationn
Hi Bruce It sounds like you want to use continuation, but the auxilliary sweep is for inner sweeps/load cases, while you need an outer sweep to do continuation. You might want to have a look at bracket_topology_optimization_stl in the Application Library. Best regards, Kristian E. Jensen, Technical Product Manager, Optimizationn
Posted: 2 years ago 2024/08/29 8:41 GMT-5
Hi Bruce
Kristian E. Jensen,
Thank you so much, and I have one more question and I would like to pick up your brain.
Did you also mean using auxiliary sweep to sweep the projection slope of Topology Optimization is not recommended?
I should use parametric sweep.
>Hi Bruce > > > >It sounds like you want to use continuation, but the auxilliary sweep is for inner sweeps/load cases, while you need an outer sweep to do continuation. You might want to have a look at bracket_topology_optimization_stl in the Application Library. > > > >Best regards, > >Kristian E. Jensen, > >Technical Product Manager, Optimizationn Thank you so much, and I have one more question and I would like to pick up your brain. Did you also mean using auxiliary sweep to sweep the projection slope \beta of Topology Optimization is not recommended? I should use parametric sweep.
