Force calculations on permanent cube magnet and coil
Posted 2024/07/06 4:32 GMT-5 Electromagnetics 5 Replies
Dear All,
I had a quick question about my model attached,
I have a cube permanent magnet above a coil. The system is trying to model a cube magnet that has north and south faces along the x-axis, and is fixed at the center and free to rotate (z-axis) left or right based on the polarity changes of the coil when current direction is changed. I have three questions:
1- When you run the model, I would expect there to be a negative y-axis force, no/negligible z-axis force (as the magnet and coil are symmetrical) and an x-axis force either in +/- based on the polarity of the coil. I.e. the coil is trying to pull/rotate the cube magnet left or right based on the polarity of it. However, I seem to get a z-axis force, and the x-axis doesn't seem to mirror the force on the cube equally in the +- when the polarity of the coil changes. why is that? shouldn't I get a relatively equal force on the cube magnet in x-axis but mirrored based on the polarity of the coil?
2- In my 1-D line plots, why are the plots not continuous and are jumpy?
Really appreciate all your support!
Best, F
