Cannot pass results from EMW study to Stationary Study - Bug or Mistake?
Dear Users,
I am having a problem with passing results from the first study to the second study of my model. I am simulating a PIN solar cell and the simulation is divided into two parts:
- Study 1 – Light (EMW): emw simulation, electromagnetic waves simulation. The electric field due to a light intensity of 100 mW/cm^2 is calculated inside the full structure. From the electric field, the divergence of the Poynting amplitude vector is calculated and used for the calculation of the optical generation term G = div(S)/(hf);
- Study 2 - Electrical: drift-diffusion model. The previously calculated generation term G is used as the reaction terms in the transport of diluted species nodes (continuity equations).
The main problem is that when G is calculated in Study 1 and used in Study 2, there is NO photogenerated current density visible from the Current Density (voltage sweep) graph in Results. However, when EXACTLY THE SAME G profile (apart from a few random fluctuations), this time calculated with the Beer-Lambert law, is used (therefore with no data form Study 1), a photogenerated current IS VISIBLE from the same graph, showing an short circuit current of about 7mA/cm^2.
The two G are plotted in Generation Rate in Results. The two G are defined in Model 1 ->Definitions->Var1.
If the two G are basically the same, why there is a problem in passing values from Study 1 to Study 2?
How can I sort this out?
Thanks in advance,
Samuele
2 Replies Last Post 2016/10/14 2:04 JST
Hello Samuele Lilliu
Posted: 9 years ago 2016/10/14 0:58 JST
Hi, I met the same problem. Did you resolve it?
Walter Frei COMSOL Employee
Posted: 9 years ago 2016/10/14 2:04 JST
Although the original question predates its existence, what's being asked about here is now handled with the Semiconductor Module (www.comsol.com/semiconductor-module) which handles the coupled frequency-domain electromagnetic, and stationary, or time-domain, drift-diffusion equations via a so-called "Frequency-Stationary" or a "Frequency-Transient" solver.
An example which you may find relevant:
www.comsol.com/model/gaas-pin-photodiode-19705
Best Regards,
Hello, Although the original question predates its existence, what's being asked about here is now handled with the Semiconductor Module (https://www.comsol.com/semiconductor-module) which handles the coupled frequency-domain electromagnetic, and stationary, or time-domain, drift-diffusion equations via a so-called "Frequency-Stationary" or a "Frequency-Transient" solver. An example which you may find relevant: https://www.comsol.com/model/gaas-pin-photodiode-19705 Best Regards,
