Diamond Young's Modolus Property confusion
Hi Comsol Community,
the Young's modulus property of diamond in the Comsol material library is
105 x 10^9 Pascal
whereas the proper property value in literature is an order of magnitude larger:
1220 x 10^9 Pascal - www.chm.bris.ac.uk/motm/diamond/diamprop.htm
1220 x 10^9 Pascal - www.sciencedirect.com/science/article/pii/0925963593902506
1220 x 10^9 Pascal - en.wikipedia.org/wiki/Young%27s_modulus#cite_note-27
I understand that this number can vary for different crystal orientations, quality, etc. but I found no data justifying the big discrepancy of the Comsol value with other values found.
Any idea why that is?
Cheers,
Erik
5 Replies Last Post 2013/01/24 12:19 JST
Posted: 1 decade ago 2013/01/22 15:38 JST
My conclusion newer trust one source always verify,
perhaps it's a typo, it's worth to send the remark directly to "support",
But in my 4.3a I read about 1.1448E12[Pa] for E at about 300[K]
So it might have been corrected since
Hi My conclusion newer trust one source always verify, perhaps it's a typo, it's worth to send the remark directly to "support", But in my 4.3a I read about 1.1448E12[Pa] for E at about 300[K] So it might have been corrected since -- Good luck Ivar
Posted: 1 decade ago 2013/01/22 15:54 JST
Okay, good they corrected it in 4.3. Just wanted to make sure .
[QUOTE] Hi My conclusion newer trust one source always verify, perhaps it's a typo, it's worth to send the remark directly to "support", But in my 4.3a I read about 1.1448E12[Pa] for E at about 300[K] So it might have been corrected since -- Good luck Ivar [/QUOTE] Okay, good they corrected it in 4.3. Just wanted to make sure .
Posted: 1 decade ago 2013/01/23 1:25 JST
Hi Ivar, I actually find the same value Erik reported in V4.3a which is an order of magnitude too low. Where do you find this higher value?
Posted: 1 decade ago 2013/01/23 1:50 JST
Hi Nagi
indeed I searched for Diamond, but as I have the full material library I took that one, the "other" one you are referring to is basic materials "C[100]". This is probably NOT diamond but some C crystalline structure (unfortunately no info is given I see)
the "nu" is also quite different
So worth a question to COMSOL support (I leave that to the discoverer ;)
if it's not a typo, COMSOL should update their INFO section to explain what it is, even if it probably is stated somewhere in on of the models, but which one ? (or the material book ?)
Anyhow just a good reminder that one should ALWAYS recheck all data, even when one believes its trustworthy ;)
Hi Nagi indeed I searched for Diamond, but as I have the full material library I took that one, the "other" one you are referring to is basic materials "C[100]". This is probably NOT diamond but some C crystalline structure (unfortunately no info is given I see) the "nu" is also quite different So worth a question to COMSOL support (I leave that to the discoverer ;) if it's not a typo, COMSOL should update their INFO section to explain what it is, even if it probably is stated somewhere in on of the models, but which one ? (or the material book ?) Anyhow just a good reminder that one should ALWAYS recheck all data, even when one believes its trustworthy ;) -- Good luck Ivar
Posted: 1 decade ago 2013/01/24 12:19 JST
Thanks for the note about diamond material, I am using that one now and the E value looks correct (at room temperature). Eventually I'll post the support about C[100]
Cheers,
Erik
Thanks for the note about diamond material, I am using that one now and the E value looks correct (at room temperature). Eventually I'll post the support about C[100] Cheers, Erik
