Acculution ApS
Certified Consultant
2 years ago
2024/08/30 3:22 GMT-5
Mech:
You assume 1 m thickness and plane strain, which is the default, but check if your setup is actual this.
Acoustics:
It is a tiny mech structure, so the sound field looks the same as this unless you go to very low frequencies, where it is less 'beamy'.
Coupling:
No need for genext (and you are not using it, as far as I can see). The coupling is done under Multiphysics and all boundaries have been selected. You place a point load right at the interface, so that node is probably excluded from the coupling.
BC:
Frequency Domain - You have input the the point load with more than the phasor, so instead of 20 e^(i omega t), you should just write 20. The 20 is a phasor of magnitude 20 and phase 0. If you need a phase also, let's say 1 rad, you write 20*exp(i 1[rad]), or you can split it into real and imaginary, so 4+3i or whatever, which has a magnitude of 5.
Wait with time-domain until you are happy with freq domain.
All in all, it looks okay. Change the load to 20, remove the genext, and you should be good.
René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Mech:
Acoustics:
Coupling:
BC:
Frequency Domain - You have input the the point load with more than the phasor, so instead of 20 e^(i omega t), you should just write 20. The 20 is a phasor of magnitude 20 and phase 0. If you need a phase also, let's say 1 rad, you write 20\*exp(i 1[rad]), or you can split it into real and imaginary, so 4+3i or whatever, which has a magnitude of 5.
2 years ago
2024/08/30 3:39 GMT-5
thanks so much, i solve it.
