Calculating Resistance without the AC/DC module
Hi, I am working on a problem where I am simulating this 2D metal sheet with various shapes cutout throughout it which changes it's resistance. When I was using the trial version that included the AC/DC module it was easy to calculate the resistance. I would run 10 amps through one side with the terminal boundary condition and then use global evaluation and ec2.R11 to find the overall resistance of the metal foil. However, in the full version, I currently do not have the AC/DC module (yet at least) and also need to calculate the resistance. I can use the electric potential boundary condition to set a voltage instead of using the terminal boundary condition. However, after the simulation runs I have not been able to find a way of calculating the resistance of the metal foil. Is it possible to do this calculation without the AC/DC module or would it be required?
2 Replies Last Post 2024/09/12 15:25 GMT-4
Posted: 2 years ago 2024/09/12 14:53 GMT-4
Hi Alexander,
I am not sure if the basic module has the normal current density available. If yes, you can integrate it across the potential boundary to get the total current.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Alexander, I am not sure if the basic module has the normal current density available. If yes, you can integrate it across the potential boundary to get the total current. Cheers Edgar
Posted: 2 years ago 2024/09/12 15:25 GMT-4
Hi Alexander,
Cheers Edgar
OR write it out in terms of components.
>Hi Alexander, > >I am not sure if the basic module has the normal current density available. If yes, you can integrate it across the potential boundary to get the total current. > >Cheers >Edgar OR write it out in terms of components.
