error message when define interpolating function in matlab (other function types work, in comsol it works as well)
Hello everybody,
whenever I define an interpolation function in matlab with
model.func.create('int1', 'Interpolation');
I get an error message (see below) - but if I write instead "model.func.create('ana1','Analytic');" or the same with 'MATLAB', the problem does not occur. Using the COMSOL interface directly, it works fine (it is just the exported model from comsol that I try to solve via the skript instead).
Does anyone have the same problem? This weird problems popping up drive me crazy :(
All best :)
Sabine
Error using com.comsol.model.impl.SolverSequenceImpl/run
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: No current feature assigned
Stack trace:
at com.comsol.model.impl.SolverSequenceImpl.m(Unknown Source)
at com.comsol.model.impl.SolverSequenceImpl.current(Unknown Source)
at com.comsol.model.impl.SolverSequenceImpl.i(Unknown Source)
at com.comsol.model.impl.SolverSequenceImpl.run(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.comsol.clientserver.impl.JobImpl.run(Unknown Source)
at com.comsol.server.internal.b.a(Unknown Source)
at com.comsol.server.internal.b$h.a(Unknown Source)
at com.comsol.server.internal.b$h$a.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl.a(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl.runServerJob(Unknown Source)
at com.comsol.model.impl.SolverSequenceImpl$a.a(Unknown Source)
at com.comsol.model.impl.SolverSequenceImpl$a.execute(Unknown Source)
at com.comsol.model.clientserver.ClientManagerImpl$d.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
Caused by: Exception:
... 3 more
2 Replies Last Post 2014/07/31 14:01 GMT-4
Posted: 1 decade ago 2013/01/29 12:47 GMT-5
ok, problem is solved -- when I tell matlab/comsol what to interpolate
(i.e.
model.func('int1').name('Interpolation surface var0');
model.func('int1').set('nargs', '2');
model.func('int1').set('funcs', {'funcsurfcp0' '1'; 'funcsurfcn0' '2'; 'funcsurfU0' '3'});
model.func('int1').set('source', 'file');
model.func('int1').set('filename', '/users/me/datasurfacevar0.txt');
model.func('int1').set('defvars', true);
BEFORE I run the solver, it works. (Or first run the solver and then create the function, of course.)
I keep this post in case someone else comes across this error message..
happy modelling :p
sabine
ok, problem is solved -- when I tell matlab/comsol what to interpolate (i.e. model.func('int1').name('Interpolation surface var0'); model.func('int1').set('nargs', '2'); model.func('int1').set('funcs', {'funcsurfcp0' '1'; 'funcsurfcn0' '2'; 'funcsurfU0' '3'}); model.func('int1').set('source', 'file'); model.func('int1').set('filename', '/users/me/datasurfacevar0.txt'); model.func('int1').set('defvars', true); model.func('int1').set('nargs', '2'); ) BEFORE I run the solver, it works. (Or first run the solver and then create the function, of course.) I keep this post in case someone else comes across this error message.. happy modelling :p sabine
Posted: 1 decade ago 2014/07/31 14:01 GMT-4
Thank you for posting this!
